removing rear light clusters
  clio 20v
open boot, remove black plastic screw, pull out light,
pull off bulb holder change bulb and replace light, check bulb ok, tighten screw, shut boot
bask in the glory of job well done and have a brew or a cig
adi
Yep that sounds about it, but when you put the cluster back make sure its not squint, locate the sockets on the bodywork.
