removing rear seats!
the bolts go throught to the underside of the car, and rust a bit on the threads, just wackm on a load of wd40 and ease them forwards and backwards to loosen them up.
also, the left hand bolt when stood at the rear of the car in mine was at an angle, so make sure your socket/spanner is on swuare otherwise you'll slip off and could cause some damage!
yep 2 bolts to remove the rear black beam thing
then 1 big torx bit (not a very common size) to remove the back bench (uprights) and the bottoms just pull out
bolts can be a bit hard as they are quite long and get rusty so just take ur time and make sure the socket doesnt slip too much
cant remember the size from the top of my head, but it was stamped on the bolt in my car. so just look at that lol
