removing seats
Car  polo, here for lols
hi i have a mk2 ph1 and i would like to remove the rear seats. I think i know how to do it and what to un screw etc but if some one could give me a few quick tips as i don't have alot of time and don't want to waste time doing things that arnt going to help!! thanks alot
sam
Pull the plastic cover off of the isofix bar that runs along the bottom of the seatback in the boot area, undo the two torx bolts that hold it in place and remove it. Pull out the seat bases in the rear (these just tilt forward and lift out) you should then see a larger torx bolt in the centre of the rear seat backs (where the split fold is) holding it to the body of the car. Undo this, unclip the seats at the top where there are held into the rear 1/4s and then lift it out. Takes 5 minutes to do assuming the bolts arent rusted solid into the body.
