removing seats
can some one please help, at some point over next few days iwill be re carpeting my clio 1.2 16 valve, 02 plate mk2.
how do i remove the seats from a dynamique model, so the carpeting can be done
i.e
does battery have to be disconnected etc...where do you undo bolts.....does anything other than the seats need 2 be removed to remove and fit new carpet??
thanks in advance.. jak
pay your £10 and you can view the guide
from memory the seats are each held on with 4 bolts easily accessed from underneath the car i would disconnect the battery first just to be safe and leave for 10 mins or so then undo connectors for seat airbags etc and the trim on door/footwell/centre console/handbrake will need to be removed to replace carpet.
Why are you replacing the carpet ?
