removing startard tweeters without removing dash
Car  Ford Focus ST2
is it possible?
i know the front and tweeter cable is joined, is there a way i can remove the door cards and not the dash to discount them?
Rob
i tried that and i can see a green plug, but not sure if thats what i need to disconnect!!!
just hope i don't want to add them back again after LOL
Rob182 said:
do i have to worrie about airbags?
and how hard is it and where do i start?
what he said ^^^^^^^^^^^^^^6
i've a real annoying rattle behind there i want to investigate :)
i know the guide said about airbags, but is a 182 so well there be any chance of the airbag going off?
I removed my dash this week:
first switch airbag off
pull all the door seal off, remove A pillar covers and unclip the alarm sensors from the brackets.
remove cover behind steering wheel, pops off, same for the silver strips.
There are 3 screws behind the passenger strip, one behind drivers and 2 under that plastic cover.
3 screw in the air vents by window, use reflection in window to see where they are.;)
2 plastic ones either side of dash on side.
Then grab dash and pull!!!!
