Removing stickers froim side of car-HELP
I had some stickers on the side of my car and ive took off most of it but its left the sticky bit underneath, what do i need to remove this last bit? Ive been told Petrol does it? Help plz
James
Be very carful. I would be against petrol.
A lot of soapy water and elbow grease is your best bet.
Try using a hair dryer on it frist to heat up the glue and make it tacky again. Then try soapy water.
if its on the paint work i wouldnt use petrol, might cause some damage..not sure.
I use petrol everywhere else though, ie plastic and windows.
When i bought my car in 01 They dealer put some stupid GT stickers on the side of each door and on the back. It was a red and white flag and GT in the middle, 3 of the f**kers!!!!!1
Then after much mockings of my m8s, I tried to get them off, took my over an hour to get them all off and I used a hair dryer to try and heat it up but it kept coming off in parts and leaving a mess.
But hot saopy water will help getting rid of anything left behind, I also used it to remove the Renault garage stickers in the back window!
got a bottle of sticky stuff remover (thats what its called) from Betterwear, used to remove a sticker on mine, no damage to the paintwork..
Try panel wipe. Body shops use it to clean surfaces before spraying. Not very expensive for 5 litres(£10 ?). Remember to give it a polish afterwards as it will remove the existing wax
3m make something call adhesive cleaner comes in a metal tin 08984 part number on it, its spot on we use it after removing boot badges at work (i work at a bmw main dealer)
