Removing the fuel rail ?
Christopher.
South Central-South Coast
Chaps
What would happen if i just unbolted it and pulled it out the inlet?
Im removing the AC with the PMS kit and also wanting to fit my matched inlets. I can get to all the bolts on the inlet so that can come off. I just don't want to petrol p*****g out everywhere. Or am I being a tard and wont be a problem ?
Don't have a good record with flammable liquids :S
Chris
If the rail is still plumbed in to the fuel line and you pull the whole lot out with injectors still attached then you will loose no fuel :) you will loose a bit if you disconnect the fuel line to the rail but it won't leak for long
yeh, I always put a tiny bit of grease on the seals to help them slide in and make sure the seals don't pinch :)
