renault clio 2002 dci
Car  clio dci 2002
Evening people
I have finally got my car plugged in as i was having cold starting problems. the code was
DF113 Refrigerant pressure sensor circuit, ground earth
i was told that is the air con? if so how can that cause a starting problem?, does anyone know i go out sorting this out?
thanks in advance
James
I think that sensor is one of them that are all in one circuit feed, if one goes down so does the rest.
Someone willbe allong shortly to correct me !
hi
Its done 100k, i thought glow plugs straight away checked them, relay, fuse. I cleaned egr valve. Check fuel pump and filter all working ok. It was annoying me so got ti plugged in and found a df113 code. only code showing so assume that's the only problem, i hope anyways.
might have to take it in to get it sorted and its starting to get cold :(
