renault diamond badge
Car  1.2 Clio Dynamique (blue)
hey there
anybody know how to remove the front renault diamond badge??
oh and also the rear one??
do they just clip off or what cause im rather puzzled :S
thanks.
Wrap a flathead screwdriver in something like a duster and place lever the bottom of the renault diamond away from the car. There are two more clips at the top of the badge, one on either side. Be brave as the clips are quite chinky, but don't over do it! It's a simple case of gentle leverage.
As far as the rear badge goes (I assume that you mean the diamond) this is a little more tricky as as far as I'm aware, it involves fiddling with the boot catch and/or lock. Have a search for it....
you could do that but you'd break it cos its screwed in from the back and you need to remove the bumper to take it off properly
"you could do that but you'd break it cos its screwed in from the back and you need to remove the bumper to take it off properly"
To take off the front Renault diamond?!
To take off just the renault diamond on the front just gently prize it from the bottom then it will just pull off, less than a one minute jobbo
the front badge comes away easy with a bit of leverage
the screwed in bit is the housing thing that dont need to be removed so that can stay put
the back badge you need to take the interior panel off the boot lid. theres a torx screw in the bottom drivers corner then the rest is jst clip on. then look for the boot button mechanism it is held on by 3 10mm (iirc) bolts undo then then go outside and pull the block thing that the badge is on. give it a firm pull dont be shy :P
once thats removed just a case of wrapping it in masking tape and doing the business
