Replace o/s driveshaft without undoing strut to hub bolts.
  mk1 Octavia VRS
As above - is it possible?
Have camber bolts fitted so want to avoid having to re-adjust the camber after replacing the driveshaft if possible.
BashRacing
undo the 2 18mm bolts that connect the lower ball joint housing to the lower wishbone and swing it out of the way,
put the steering in full lock so the track rod is at full extension to make it easier too.
leeds2592
  Bean 182 + E70 X5
Yep, no need to undo the bolts.
Did my CV boot recently and didn't undo either strut bolts.
