Replaced ht leads now starting problem - help
Car  CLIO 172 2003
Hi all i had a massive misfiring issue which was fixed by changinf the leads, as 1 was crushed between the inlet manifld and head,
Since changing them it started loveley and ran fine but once the enging is off it wont re start, it fires 2 or 3 times then just turns over.
Any idears to what this can be ?
this is becoming a ral problem
thanks in advance
i put them in the same order as they came off, 1 to 4 going right to left, i did them 1 at a time so i didnt get them confused.
But sureley it wouldnt start full stop or run on 2-3 cylinders ? its runnign fine then not re starting after it had a good run ? bloody thing......:S
