Replacing front foglight 1*2
what side is it on?
Remove the wheel and arch liner and they are on 2 torx xcrews iirc. On the passenger side u have the accoustic valve to undo/work around and on the drivers side the carbon canister may be in your way.
its quite an easy job
Cheers Burp, Is there any need to remove the front black moulding to replace the fog or does it simply come out from behind?
Its a Very easy job but as said if you have a Small handle Torx Screwdriver it will be even easier, I didn't tho so custom made a Tool LOL
