Replacing/Removing wing
JJT
  1.4 16v Dynamique+
Ive done a search and found not a lot therefore decided to start a thread as im sure someone knows and will save me time!!
Do i have to remove the headlights/bumper to replace the front drivers side wing?
Ive undone about 20 bolts and the wing is coming off but is still clipped in at the front somehow and i cant work out how to undo it.
Cheers...
from memory 2 or so bolts under the bonnet?
you wont have to remove the headlights but might have to remove the front bumper
4 bolts under the bonnet, two down by the skirt. 2 inside the door, and about 3 inside the arch from what i remember and still wont come off.
Will take bumper off tomorrow.... easy???
You have to loosen the headlight, as the healight has a plastic "bolt" that holds the front of the wing in place...
EDIT: I didnt have to remove the bumper, just loosen it.
