Replacing standard Brakes on clio 1.2
Car  '02 1.2 16v extreme
Hi All
first post :)
i am replacing the front Disc's on my 2002 1.2 extreme and was wondering if you chaps could give me some advice on the following?
1.what disc's do i need? i know they need to be vented but does anyone know what size they are? as the website i checked for discs had 2 options for the vented disc's for that year of car (238x20) and (259x21)
2.ive done lots of things like this before but is there anything special i need tools wise? or is it as simple as unbolt the caliper push in the piston and whack on the disc?
thanks alot
Speedle :cool:
With it being a 1.2 id be inclined to say the smaller size. renault discs are cheap however.
tools reqd
17mm spanner
13mm,18mm and 19mm sockets
screwdriver flat blade
torx 40
big grips
as you say though simple enough job
260mm disks.
Dead easy you got it might need an impact driver to get the thorx bolts off the brake disk or have to drill them off.
