Replacing thermosta and CTS?
Trainerbrow
  Mk1 Audi TT 3.2 V6
Does the mating face of the housing unit need a gasket when replacing?
Or do I use sealant?
  182
There is a seal if you have removed the whole housing off the side of the cylinder head!! Instant gasket or similar is whats used iirc.
But if you have just removed the little bit that holds the thermostat thats bolted to the front of the housing , then the o-ring on the thermostat is enough..
Trainerbrow
  Mk1 Audi TT 3.2 V6
I see. So I dont need to remove the whole housing. Thats cool
