Rev Gauge *help*
  mk2 ph2 clio 1.2 extreme
Hey i have a F & F rev gauge and put the wire around the ht lead but the rev gauge is not read n the revs prop anyone help or know how to wire a rev gauge up would i have to connect it to the ECU ??? insted is put n the lead aroudn the HT leads to pick up the magnetic pules ??
cheers get backto be ASAP
M
mini-valver
I fitted one to my corsa, had to put one cable into a live feed behind your clocks, one to a terminal on the coil and one somewhere else. Needs to have a good connection to the coil,doesnt go on the HT lead....
