Reverse light problem.
  Zafira, Mr2 Clio 1.5 dci
Hi, My reverse lights aren't working.
Checked bulbs, fuses etc. When car is in reverse the passenger side light is getting power, but bulb won't light, driver side is getting no power at all.:(
Thought it might be the switch, but would power get through if it was?
Any help would be great.
Kat
  2008 Clio 1.4 Dynamique
Its probably the reverse light actuator switch. Should be located somewhere on top of the gearbox casing, though Im not sure about this. Ive only had a problem on the Audi I used to have so I cant say for sure on the Clios. Hope this helps Kat.
Thanks shorty, can someone confirm the location of the switch in my model so I can test the switch, It's a 1.5dci Billabong. Is it not under the gearbox? Need to change brake pads so will have the wheels off tomorrow anyway.
