Reverse Loud Knock
where do you get this part from lads? how do you remove the old one from the end of the shaft? do you need to get the new one pressed in?
few more details please i think i now have the same problem;)
No need to press it on. You just bash the new one on.
I think Harry had an easier job than me I had to use a sledge hammer to remove my driveshaft from the hub and to remove the sleeve from the other end.
I think the part is available from Renault or I could give you the number of the place we got ours from. It's 70 quid inc delivery.
yes mate number would be great also part number or what its called would be good to mate
cheers
01254 238163 is the number of the place. Think they specialise in renaults.
The guy we spoke to was Kieran. Don't know what the parts called but just explain it hell know exactly what you mean.
But I'd check your local dealer first as I'm sure they just send you a genuine part from Renault anyway.
I'll have a look when I get home. But full lock or driving straight had no effect on mine. It done it all the time.
Best way is to stick the handbrake on put it in reverse and bring up the clutch to the bite. If you get a thud it could be that. Try it in first and reverse a few times.
It was a mission to do but it's done and the noise has gone. :) thanks again Harry
Awesome!!! Glad I could help both of us lol
Sorry I haven't replied been working all hours, haven't had chance to think about cars.
I should be claiming commision from him with the amount of business he could get from us lot on here :p
i had a wheel bearing sound, i'm wondering if it was the spline rubbing away as their would be movement not a tight fitment, will see if the wheel bearing noise disappears once all back together hoping to get it all done by friday.
I would say if you're getting these early warning sounds take it easy, as I didn't and it went and lost all drive and was stranded, just lucky I work at a garage and got it recovered and got the mechanics working on it straight away!
part arrived the exact same sleeve as the one taking off except it was perfect working order!!
​part number is - 7700858979 RRP at 15.04 + Vat
