Revving its nuts off on start up
stevem42
  Silver182 and RB 182
Hi I've just fitted new engine loom as car was non starter after fitting new engine ....engine now revving on limiter on start up ......disconnect throttle wiring and it drops to 1500 rpm any advice be helpful
Thanks in advance
  DON'T SEND ME PM'S!!
The Throttle body might need to find it's zero point. Try turning ignition on and leaving it for a few minutes, then repeat a few times. It might even be worth removing it and cleaning it out.
  Clio 1.2
I had this problem, pluged in a diagnostics and got a code for the throttle position sensor so cleared it and havent had a problem since,
could also be the ICV, I just took my throttle body off and cleaned it out with carb and TB cleaner :)
