I fitted my Jenvey bodies a month or two ago and it ran really rough - the balance was miles out and the TPS raw values were wrong etc.. etc..
It did however register around 14 on the wideband on idle
I've now set the idle screw, balanced the bodies, and configured the TPS raw values on the omex - it idles smooth as silk at 950rpm. It's not popping and banging at all anymore and generally sounds spot on
Only weird thing is it's registering 10.2 on the wideband on idle which is quite rich
As soon as you put even a little tiny bit of throttle on it goes to 14 but on idle it's rich
Is there a fuel trim setting or something that I can alter. Or is this a cold start fuel enrichment or something?
I've let it run for 30 mins and I can't test if the fan cuts in because it only ever gets up to about half on the temperature scale (I assume a combination of freezing cold garage and the engine running rich)
Or... is this something I shouldn't care about as long as it idles and runs spot on?
My only concern is I'm getting an exhaust made up with a sports cat in and don't want the cat dying due to the wrong AFR
