roll cage help
Car  clio 182
Anybody know if a full cage from a ph1 172 would fit my 182?
Dont have a huge amount of info at this atm, i have been told a hole will need to be cut in the dash tho??
Any help would be great.
What kind of cage is it? weld in? bolt in? 6 point? multi point?
This is the original discription
Renualt clio 172 ph1 omp rollcage removed from my clio track car. Complete with all bolts and Centre box section. This is a bolt in cage but does require some boxes welding in to mount the centre feet in!
I contacted him to ask if it would fit my car he said it should, but on his he had a hole in his dash.
By 6 point do you mean the amount of contact points with the floor? If so then yes!
