roof lining
Gaz_
  Extreme mode
anybody removed it, or is it a no no?
i've got a rattle from mine (99% sure its the arial cable rubbing against it) and its right above me head, which is annoying........
help people!!!!
:cool:
  Civic Type-R
Just pull on it I think from the top of the windscreen? Think its just stuck down. Could be wrong though :)
it is very delicate so be careful. wen i had my aerial ripped out of my car i had it remove my lining and it is so flimsy!!!! reno were going to charge me 150 for it so i did it myself!! good luck!!
Gaz_
  Extreme mode
took it off today, seems the rear hadn't bonded properly, causing the rattle/vibration, refitting again tommorrow with LOADS of stickaflex lol
pretty straight forward to remove, just remembering to take your time lol
  "Navy" N17 TWO
Yeah - dam sunroof is only a novelty :S a rattling one too :(
I'm finding it difficult to get some of the clips removed - just hard to budge :dapprove:
  "Navy" N17 TWO
That's exactly what I have in mind too
Might even save a few quid and retrim the headcloth in alcantara to complement the install that im putting in. seen a clio with it done - looked awesome :cool:
  Punto/Clio GTT
lol i had to take mine out on my mk 1, it was bonded in had to pull it down n get a blade down the back n slice it. the roof was bowing to f**k, lol, v v flimsy. bolloxed all my knuckles up doing that :\
  "Navy" N17 TWO
It seems like the material is stiff enough in mine, it's the plastic trim and other gizmos that's holding it up that are annoying me :dapprove:
pull too tight and the car would probably fall apart lol, well something would break at least without a doubt
  "Navy" N17 TWO
How do you get the clips for the sunvisors out? I've taken out all the screws and the sunvisor itself is down but the clip for securing the visor won't budge :mad:
Gaz_
  Extreme mode
its a t**t..... best way i found was undo the torx screw fully, then i think the clips need pushing together and pull down whilst 'rocking' front to back if that makes sense? the grab handles are the same and a poor idea imo
