I have trouble selecting 3rd when changing down from 5th or 4th whilst also applying the brakes heavily. 99% sure it's the engine mounts letting the box move too far and not allowing the selector shaft to quite slot the next gear.
even the gearbox in my escort gti was faultless and that suffered EXTREME abuse to make the car go anywhere
renault just failed. badly.
3rd gear crunching from 44k.
172 Ph2
Edit, and as above. Heel-toe every gear, all the time. Essential to prolong RS engine mounts and gearbox.
another edit:
If I owned another, i'd be trying 75-90 gear oil in it as my 3rd gear would only crunch when gear oil was really warm. Anyone tried 75-90?
ktr uprated engine mounts seemed to have helped smooth my gearchanges. my car is on 55k and running really well. im not too rough through the gears and the car does get driven hard on a regular basis, not every trip, but often enough. i also try to rev match when downhifting. might start using the heel toe method.
Yes the Castrol oil I described as not working so well earlier in this thread was 75w 90. It is the Elf oil and only the Elf oil you should use for best result. My friends changed from Castrol to ELF and all problems dissapered. The Elf oil is specially developed for Renault JC gearboxes. Have also heard that it conatains some friction adetives a bit like a plate diff oil.
Heel toe (or side ball as it should be called these days) is good, doesn't quite solve my problem but I use it pretty much 100% of the time. Can't remember the last time I didn't rev-match a down shift.
KTR engine mounts are tempting but worried about the extra vibration.
no need to double declutch (there hasn't been in cars for about 50 years) - you're just torturing yourself
could blip the throttle to match revs to the those of the lower gear whilst downshifting though
Forgive the newbie question but what are the costs involved in replacing engine mounts?
I'm not yet convinced as to what this thread is adding to our dirty little lives. Surely there should be a 'Who's not had problems?' thread. Without one this just gives a shiny platform to the poor buggers, who's kit has failed, to voice their well deserved pissed offedness. Fine, if aimed at the manufacturer but this is splatter gunning anyone and everyone.
This crap creates urban myths and all manner of fashionable hysteria that usually births the 'chocolate _ _ _ ' phrases.
Sorry, Just my 2 pence worth....![]()
