RS grill missing plastic piece
Car  Clio 1.2 Expression
Hi
I just fitted my new RS grill to my Clio Expression 1.2.
After fitting it i noticed on the old grill there was a plastic part that came off. It looked like something to move air over to the rad.
I dint fit this to the new grill.
Will it be ok without it? or would I have to remove the grill and fit it?
Ben
I cable tied my on iirc. Think i broke the clips on it though.
Should be able to fit it with the grille still on
you shud be ok without it, i think it just block the alternator from view. and you can fit it to the grill without removing it because thats what i did
I'm pretty sure it's to stop some of the sh*t coming through the grill getting onto the alternator. Could be wrong though.
Anyway Ive tried fitting the plastic piece back onto the grill with the grill on my car. The clips fit and secure into place on the bottom but don't reach the top. Anybody else had this problem?
nope m8y the alternator is lower down more or less underneath where you put the oil in your engine on my car. The plastic bit is there because of where the alternator is. I fink old mini use to have a piece behind the grill because the alternator was the close to the grill :).
It wants transferring over, its the alternator rain guard. The non rs one is slightly too short to properly fit but nothing two cable ties can't sort out.
