RS Tuner help
only thing i would suggest email henk
it took me 3 maps to find the right one as i had a diff ecu
you could try it but it may bring enginemanagement on liek it did with mine
SAVE YOUR ORIGINAL MAP FIRST!!!!!!!!
can always go back but i would contact henk cause it dont seem to be a map for your ecu there
send him your original and he sort u out
Thanks mate. So i will write ecu to
6500_2A08 .rst or am i best using 6500_5404 .rst Then i can use the 5404 cal?
and write cal to
6500_5404 RON98 june 2009.cal
6500_5B03 RON98 dec 2008.cal
What did you do in the end Ben, cos i've got a similar problem?
Connected mine up for the first time this afternoon and i'm running: 6100 2A06.
Backed up my original ECU, but a bit unsure whether to update to 6500 like you. And if so, which one! I'm thinking of updating to 6500_5404 so I can write cal to 6500_5404 RON98 june 2009.cal, because it's the latest version!
Is this what you did by any chance?
cheers, Chris
Yes thats good. Remember updating the software takes about 25 minutes. Needless to say your battery must be 100% or attach a battery charger.
If your battery gos flat half way thru does it damage the ecu ??
