Rs Tuner question..
  Audi TT 3.2 V6
Hi,
If i reprogramme my ecu using an rst file with rs tuner, am i right in thinking that i then don't have to do a calibration with a cal file?
Which is generally the best map to use? (presuming my ecu is the correct version to be used with your recomendation)
Thanks, Russ
  PH1 172 Sport
Depends whats availible for your ecu but if there is several its best to try them all and see what your car responds best too.
  RB 182 & Lotus Evora
the rst file is the ecu base settings. The cal files are ontop of the rst file which set all the parameters. So yes you do need to play with the cal files if there are some available for your model.
