So, by way of
1) Summarising what's been confirmed
2) Waiting for gaps to be filled in
I must admit I'm a bit unsure what I need if I only want the 98 Ron map. Or rather what I need to spend my money on after I get a 2nd hand one. Think I'm over thinking it
As per this ^^^. AFAICMO (as far as I can make out
You need an unlock code (£33) if you want to remap (regardless of 1*2, rs tuner version, or desired map.)
* You don't need an unlock code for general fault reading.
* Depending on what you what to do (ABS, airbags etc) you may need to purchase the additional module.
Then according to Thomas:
It's not about what rstuner is, it's more to do with the map.
I could use the 98Ron map that
Pat 182 (still need to give you the disc back) gave me. However I couldn't use the pops & bangs map that @
adamjcat had just brought.
-Danman- also bought a RSTuner and could use the 98Ron map I gave him, but couldn't use my P&B map that I had just purchased.
Basically Henk has started including the VIN (at a guess) in the map so it will only write to that car. The older maps are fine but ones purchased recently are not.
You can "file share" old maps regardless
You can't file share new maps as they are locked by (?) VIN
Still leaving slight uncertainty:
* All pops & bangs maps are "new" therefore can't be shared?
needs confirmation
* What (date of purchase of map?) counts as "old" and "new" ?
needs confirmation
But you STILL need to match the map to the ECU version, according to Chip:
As for if you can use the map, only if their car is the same revision as software as yours, so no good trying to put a ph1 map on a 182 etc.
* Where there mid-manufacture revisions?
needs confirmation
e.g. does an 04 plate 182 have the same ECU revision as a 55 plate 182 (and just for the sake of clarity this is the version of ECU hardware or software? But nothing to do with the lookup tables that constitute a standard map as these didn't change mid production, only between ph1 172, ph2 172 and ph2 182?)
Potentially (any RS tuner + unlock code + sufficiently "old" map that it doesn't lock to vin from someone friendly + map sourced from car with same ECU revision as yours) = map your car for a net £33 (40E)
Failing that (any RS tuner + unlock code + new map from fastchip.nl website so guaranteed to work) = map your car with 98ron for a net £57.80 (70E) or £66.06 (80E) for P&B
Yaya? Nay?
