RSI rear brakes, 16v ons bolt straight on?
Are they actually the same discs/calipers as the 16v/williams?
Pads and discs need changing but if the 16v/williams use bigger brakes I'd put those on.
Bit confused as to whether yes they just bolt on or yes all three cars share the same discs etc..
Are they actually the same discs/calipers as the 16v/williams?....
... but if the 16v/williams use bigger brakes I'd put those on.
Its onlt the fronts that are bigger on the Valvers/Williams, 259mm, compared with the RSIs 238mm.
If you wanted the bigger front brakes, all you need is the the carriers and disks (all of which can be had off from your local scrappy;)) the piston is the same.
Makes a big difference by the way.
