Iirc that is at the wheels (136bhp)
Works out at just under 160bhp / 144lbft I think?
Thats having 17% transmission loss.
at the wheels or flywheel, are you adding the 33kw of drag into that?
At best I can only calculate it to 161-162bhp.
If that's correct, that's what I'd expect from an OEM engine.
If it's at the wheels it's a good figure.
Surely the onboard performance thing isn't gonna be massively accurate? Get it on the rollers before you start getting upset
what were you expecting?
what manifold is it?
i have no idea what manifold it is tbh but it has some nice welds on it, doesnt look cheap, i was hoping for somewhere between 155-160 at the wheels with what i have
33kw of drag, thats a dam s**t figure then, as i have a phase 1 172 with
4 branch manifold aftermarket -There is nothing restrictive about the standard exhaust manifold. In my honest opinion... Pointless upgrade.
decat - will help the engine expel gasses, not going to gain much power.
mongoose system - minimal gains at best.
182 inlet - again, will help engine breath, but not a huge difference.
98ron map - debatable.
94k on the clock
how disapointing!! feel quick as f*uck tho - This is the most important thing, if it feels quick... who cares what the figures are?
its probably a standard one (good though)
i didnt say 190! isaid around 155 whp so 181 bhp
right so just enjoy for what it is then!!! lesson learned
Exactly, if it feels quick on the road don't chase figure as you'll never be happy.
There red is not much you can do to the 172 without spending ££££ which actually give real world difference.
Ported inlets
V6 airbox....?? espace or clio v6?
98 Ron map....i have
Exhaust & decat...i have
is the usual modifications that get around the 170-175bhp figure.
There is not much you can do to the 172 without spending ££££ which actually give real world difference.
Ported inlets
V6 airbox
98 Ron map
Exhaust & decat
After that it's cams - RS2 inlet - ITB - Supercharger/Turbo.
Either. Ported inlet will not give you 10+bhp however will help the clio breath more efficiently.
I'd just be happy with what you have.
ok. is the bigger v6 filter worth it?
I've got a better question?
Is it worth spending ££££'s on the car to increase the power (or) start off with a more powerful car...
Putting that aside, my Ph1 airbox for (£50) was a nice little upgrade however others have said opposite.
decat
mongoose system
182 inlet
98ron map
94k on the clock
but i also have
decat
mongoose system
182 inlet
98ron map
im not upset just had hi hopes i guess seeing as i already have
decat
mongoose system
182 inlet
98ron map
but i guess none of that seems to make a difference as iv seen other on here getting 156bhp with just a filter and exhaust not including a remap and that at the wheels
V6 airbox....clio or espace??
98 Ron map.... i already have
Exhaust & decat....i already have
I hadn't quite noticed, could you clear up what mods you've got?
Exactly. Sod the figures and enjoy the fact you've got a good car that drives wellright so just enjoy for what it is then!!! lesson learned
