Clio 172 Cup
OK just an update on where the 172 Cup has got to with its little mis-fire issue: Changed plugs (NGK OE), changed HT leads (Magnecor 8.5mm), cleaned throttle body, cleaned TDC sensor, checked emissions @ MOT station (oxygen 1.5 rather than 0.5 apparently) & re-set parameters according to mechanic - not sure what he meant by that to be honest. Apart from the coil pack what else is there to try?! This is starting to get expensive & just a bit annoying now as it STILL mis-fires at about 2k revs & clears itself by about 3k revs. Car is standard except for a Piper Cross Induction Kit (the cause of the high oxygen reading?). I know the exhaust has seen better days but surely that couldn't be the cause could it? Any help and/or suggestions gratefully received! :S
