Running without lambda sensor in decat for 2 days....
Pep
Living Dangerously
Car  M2,XJS,S1000RR
Will this damage the car?
Can't get the one out of my standard Cat so thinking of buying a new one at renault on monday, will it cause any damage?
How much are new Lambda sensors?
Help quick please.
im sure as hell they aint cheap from the stealers, cant see it doing damage aprat from to your MPG
How much will the mpg go down?
How much is not cheap?! £30? more?
have you tried heating it all?
and i'd think twice before driving without it to be honest.
Yep tried heating it, doesnt want to budge, and i don't really wanna be pissing around again fitting it back on then the decat another day...
Maybe a job for birchdown when i go up next week then I guess...
i think that the management will try to run rich if the lambda is not working, but if for whatever reason it ended up going the otherway, you could do a fair bit of damage.
Theres my persuasion then I guess.....:(
Looks like I'll have to wait, although I'll see how much a new lambda is on monday anyways and if it isnt too much then i might just buy another, might work out cheaper than birchdown doing it!
WD40 sprayed on for a few days... should come off easily enough after?
tried a spanner with a big bar attached for leverage?
WD40 and the other oil tricks dont work.
I got a spanner with a 2ft handle on it and clamped the exhaust down to get the bloody thing off.
spanner on and give it a clout to shock it off
Should be fine without for a few days however, ECU is designed to run rich if the lambda is faulty/missing
Given in, std cat back on.
Emmisions light is on, but comes on and off as it pleases anyways so thats nothing new!
it's blowing slightly now too, sounds like i've got a turbo fitted!!
if you're really struggling, just take the cat round to kwikfit/whatever and throw them a fiver. there'll be a few open tomorrow
Won't get chance.
And to be honest I would rather Birchdown did it, I'm traveeling up there anyways so not a big deal.
I'm getting my coilovers set up Tomorrow so I'll reallig the cat then and get it to seal properly, although the noise is quite addictive!!
Lambda in decat , this means the second one ?
Leave it, engine(management) does'nt do anything with this one, it's just there to tell you the cat is on it's way or not.
First one, near/on manifold, is the important one. This one has the data for the ecu to go leaner/richer
When this one goes bust your car (enginemanagement) will go in a "safe" mode , making it run rich , or so people say
would'nt worry about the second one at all
In fact, some people (i have) just lost the second lambda somewhere because there was no fitting in the decat ; i just tied the lambda up somewhere under the car , leaving it connected to the wiring. Does'nt do diddly to the cars mixture etc..
^ Hmm interesting.
It's booked in on Friday to have my new brake bits fitted, so I'm getting them to do the decat too, saves me having the hassle again to be honest.
I only wanted to do it myself so I knew how to do it in the first place, but now I do I'm happy to sit back and watch someone else work :D
lamda like 20 quid from our suppliers you just gotta camp old plug on the end of new wires, included in kit
why the feck would you pay 100ish for a lamdba sensor, are you mental??? :S
De-catted my PH2 172, first lamba from the the engine is needed.... second one is wrapped up under my exhaust heat sheild thinking its burning sweet sweet air... cant be doing with the emissions light along with the serv & air bag one on lol
^ Thanks mate.
Shame I couldn't get the damn thing out, bit annoying buy just the way it goes I suppose.
I can't wait until I'm rich, got plans for a double garage to be build with some ramps etc etc, will make jobs like this so much easier!!
WD40 is pointless !
you need penetrating oil like plus gas or similar, wd40 wont do ANYTHING to help you get it out
As you'd fully removed the cat you should have clamped the Lambda in a Vice and used the cat as leverage if that makes sense, would have easily come free
never thought of that rich! Good idea!
My teeth are weaker than my array of adjustable spanners, think I'll invest in a proper spanner set come payday.
I have fitted so many clios with suspension etc from springs to coilovers and only used 2 adjustable spanners haha!
^ Cheers mate.
My mpg seems pretty good, going to work and back is a short journey so never goes above 4krpm, and when i get chance it gets a decent hard drive and i get around 32mpg.
Interesting stuff though :)
