Just received a safety recall for the bonnet catch on my 2003 Clio Cup remember seeing pictures a few years back of Clios with bonnets against their windows, can this be done by my normal garage or has Renault got to do it as it's an old car now?
Russ, they took a long time to recall you, it's been at least 2 years since the recalls started. Might as well have it done by Renault, it'a all free. They'll be tempting you with a new car as well.
Yes just got off the phone to them and it seems like they are just going to spray some grease on it, more worrying is the reg didn't register on their system but the chassis number did he thinks it had a private plate on it, I only use the car for sprints anyway and drive to events, I think aero bonnet pins will be going on as well, I've been lucky then as the car has been driven hard at some events and no problems, just my luck as the car's been faultless after a service at Birchdown, thanks for the replies.I'm also worried it'll come out slower than it went in as it's a main dealer.
And servicing and stuff, got a card telling me my mot was due from them the other day, only prob was it was actually up in august, so no idea how they gained 3 months.
Also the whole catch was changed on mine not just sprayed, thought it was the same for sports and non-sports
you'd be silly not to just go and get them to check it really. I lubricate the bonnet catch on every car I see now, there's a lot of them get very sticky and it takes about 1 minute to free them off and grease them up to try to prevent it happening again
Take your car to Renault and let them inspect the catch. We have had clio's in at work that have had 2/3 new catches because they corrode. If its corroded it needs replacing and renault will do it free of charge
Look in your engine bay and see if there is a blue sticker with lots of squares in it - there should be a cross on box K4 to say its been done. But as I said this doesn't mean it won't corrode in the future
