you dont need omex for schrick.smt 6,unichip or reflash ecu should be enough.i am talking about fast road cams not rally..Ali said:in english.
The std ECU will run mod'd cam's to a certain degree. But you normally need omex 600 or such like.
Spk to BenR and Fred.
stan if the car was mk1 with cable throttle ok but the question is fbw.check the modified clios in the forum;i didnt see any clio with fbw using schrick or 275/267 catcam.(sorry about my poor english)stan* said:the problem with higher spec cams is the over-lap interferes with the MAP reading casuing fuelling issues low down...rough idling. so as long as the duration isnt great enough to cause this problem, then a remap of the std ecu would be ok.
Ali said:what is fbw? lol.
I don't think anyone on here has cams and a std ecu.
The mk1 boys do, but the duration od the cam is somewhat less advanced.
matty w said:the hillpower cable throttle conversion i've got uses the standard ecu,just remapped
The pin outs for the ECU are different plus the phase1 doesn't use a UCH which is involved with the startup. If someone can sort the ECu maps into the phase2 ECu then the wiring looms can easily be sorted and yu'd just need a phase1 throttle body and peal. I'm interested how Nick sorted this though as there a few ways round it ie using stck ECU/fiddling with the wires on stock ECU/fiddling with wires on Mk1 ECU/using a Mk1 ECU.MarkM said:The reason the cammed mk2's you have seen do not use the standard ecu is because of the cable throttle setups that use the throttle position sensor for mapping rather then idle problems with wild cams.
There is not a cable throttle conversion available at the minute without useing a standalone ecu. I dont think mk1 172 ecus are compatible with later 172/182s.
i think thers only one way mateedde said:The pin outs for the ECU are different plus the phase1 doesn't use a UCH which is involved with the startup. If someone can sort the ECu maps into the phase2 ECu then the wiring looms can easily be sorted and yu'd just need a phase1 throttle body and peal. I'm interested how Nick sorted this though as there a few ways round it ie using stck ECU/fiddling with the wires on stock ECU/fiddling with wires on Mk1 ECU/using a Mk1 ECU.
MarkM said:what is included in the kit to convert it, is there a new ecu
your best speaking to nick
ahmet said:stan if the car was mk1 with cable throttle ok but the question is fbw.check the modified clios in the forum;i didnt see any clio with fbw using schrick or 275/267 catcam.(sorry about my poor english)
so what kind of cam we can use with fbw and piggyback remapping?for example i have dastek unichip with fbw on my mk2 172.i want to keep unichip,so what is my cam choice?pls give example and we sort it out.BenR said:no, nobody runs any cam with any decent overlap values, because fbw will not support fluctuating map signals.
I explained it to you before already, the car WILL stall if running the stock idle strategy, this means piggy back systems and simple fueling/ignition remaps.
this question is for you fred:can i use schrick with unichip?(my car has fbw dont forgetFredYozzasport said:the FBW is fine with the schricks
ahmet said:this question is for you fred:can i use schrick with unichip?(my car has fbw dont forget)
ben say no now you saying yes.i am gonna get crazy.MarkM said:Yes!
ahmet said:ben say no now you saying yes.i am gonna get crazy.
yesahmet said:this question is for you fred:can i use schrick with unichip?(my car has fbw dont forget)
BenR said:i said no to the wildest sport profile from cat, that will not run stable on FBW as i've explained numerous times before in your PM's. 2411 will not run stable.
ahmet said:yes i understand that but my real question was schrick as you see from the thread.isnt schrick wilder then 2411 catcam?
so if schrick was a catcam what would be the duration ben?measure schrick the way catcam do pls...not:i am waitin for your new profile anywayBenR said:Shrick and catcams are measured in a different way so you cannot compare the duration events.
ahmet said:so if schrick was a catcam what would be the duration ben?measure schrick the way catcam do pls...not:i am waitin for your new profile anyway![]()
FredYozzasport said:??? my inbox is full
