Scottish Tarmac Rally Build
20151126_212020.webp 20151126_212106.webp 20151212_163547.webp 20151212_163603.webp 20151220_121216.webp 20151106_094556.webp 20160119_171043.webp 20151223_112548.webp 20151126_212020.webp 20151126_212106.webp 20151212_163547.webp 20151212_163603.webp 20151220_121216.webp 20151106_094556.webp 20160119_171043.webp 20151223_112548.webp
Love to have reiger but way out of my budget, just going to use Bilstein b14 with pms solid mount and brace and pms reinforced rear beam.
What box are you using?
Hi, Are you using the pure motorsport stub axels for the bigger bearing discs ?
Hi
Yes sort of
Not using standard rear brakes
Using alloy hub brake rotor and bell
I originally had AP calipers and 295 - 300mm rotors under my 15" wheels. (I turned them down slightly) They have worn a bit too thin so I went back to standard and did a deal on some ds1.11 pads, brembo high carbon discs and have had no issues. Thought it would have had a bit of fade on the Manx but they were great.
got some more work done
big valve head fitted, next to sort out some cams
light weight rear hub and brake set up
I take it that is a bespoke setup your running?
Is it for under a 15" wheel..standard rear clio caliper ?
Looks great :up::up:
