Serial ATA.... HELP!
  Clio 197
Can't get this damn thing to work.
I have a normal IDE HDD - for which I've removed the Jumper to make it a slave.
My motherboard is not recognising the SATA drive, so I've set the jumpers to manually set it up.
So, that's been done.... but how on earth do I make it a primary master ? ?
:S
  Monaro VXR
What i was thinking you should have no jumpers to set on a SATA drive they auto configure. Just make sure its plugged in right and if you plugged in the power cables just 1 daft question some of the drive can take both standard power cable and the sata power cable type...If yours is like this you didnt plug both in did you? Cause the drive would go pop if you did.
Otherwise make sure you have sata enabled properly on the motherboard
  "Navy" N17 TWO
Try this maybe
go into your CMOS/BIOS and select the option
Set default settings
then check that SATA drives are enabled
  Clio 197
Ok... it's all working.
I have Primary Master as my SATA.... and my secondary Master as IDE HDD.
(I had to move my IDE HDD to IDE Cable#2, so that it was not the default primary).
Question: How do I get myself a boot-menu? Ie, how to I get the computer to ask me which disk to boot from?
Also, a slight technical issue: the SATA is not recognised every time I start the machine... sometimes it is, and sometimes it isn't.
  Audi S3 225
Check there isnt an updated bios for your motherbaord, they normally fix problems such as yours.
  RB 182, 1275GT, C220
The boot order is in BIOS. If your mobo is pre 1999 it wont pick up a SATA drive IIRC.
