Serv, ABS and TC light not fixed
  Clio RS 182
If anyone has any input that would be great as i'm at a loose end.
Basically driving home from work and the Serv, ABS and TC lights came on, turned the car off and back on and the lights dissappeared.
This happened a couple more times so I checked the ECU fro fault codes and found none,
I followed the following post to adjust the brake light switch.
http://www.cliosport.net/forum/showthread.php?t=307978&highlight=brake+switch
This didnt work
I have checked the brake fluid, bled the brakes and even changed both front calipers as a bleed nipple snapped whist I was bleeding them.
Still not sorted the issue
The lights came on again today and I went to pull away from a set of lights quite quickly as I was in the wrong lane . As I pulled away the TC didnt kick in and i sat there for a sec wheel spinning.
This has left me a bit puzzled. I still think its a problem with a sensor but not sure which one?
I am left thinking the following but i could be way off as im not a trained mechaninc:
1 Do clios have independent TC sensors or does it reley on the same sensor as the ABS?
2 How expensive is it to replace the ABS ring and sensor, and if it a hard job??
Thanks for taking some time to help!!
  clio 182 cup
This didnt work
i had a smilar problem. turned out it was a blob of grease on my abs sensor where my cv boot had leaked. just wiped it off and put a new tie on the gaiter and didnt do it again.
  Clio RS 182
Thanks I will give it a go see if sorts the issue.
