Serv + abs + esp lights on?
  GW 200 Gone :( BG182
Had this happen a few times, seems to be when i use something electrical in the car eg automatic lights, horn etc. just comes on randomly, any idea what it is? Ta, Craig
Through reading all the threads about the abs light last night it seems to most common fault if the esp light is also on is the brake pedal sensor needing adjusted.
jenic
Try cleaning the connections on the old sensor before buying one, saved me money!
You also need to get it on a code reader (a decent one for abs problems!) to find out if its a sensor, and which one.
Cheers will give it a go :)
