running an old school proliant rack server here......although the cpu fan in the back is wayy too loud and getting on my nerves now....
its in a rack in the garage, so its cool enough, also the racks got fans on the rear so i thought simple enough il unplug it and disable the cpu fan warning in the bios....
thing is...there is no bios on proliants apparently, you have to use the 'smart start' cd to configure the server....ive done this but it dosent go into that much detail to disable warnings etc...
anyway i was trying to think of a simpler way of getting round this....
the cpu fan is connected with a 5 pin plug...although one of the pins is blanked off....
the 4 wires are [YELLOW][BLANK][RED][BLACK][BLACK]
is there any way i can cut this connector off, and solder a resistor or small circuit in place of it to make the server think the fan is there? the fan is '12v DC-1.0Amp'....
if anyones electronically minded and could think of a way round this it would be appreciated
