Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Every now and then these 3 lights pop up and stay on until the car is turned off ? when re started these light go. Sometimes they will come on quickly and other time they will stay out and not come on ?
The 3 lights mean Your breaks have been applied but your brake lights have not been eliminated. Their is a sensor above te break pedal you need to use a screw driver and adjust that a little and it should solve te problem it can also happen another way but the light are different on the dash and it means the lights have come on but no breaks were applied (too sensitive), fix is te same though just adjust the break pedal sensor. This happend to me and I thought I would see if all systems were ok and my abs and traction controll did not work so if they do come on be warned haha.
