Over the last week or so on random occassions the service light has been coming on with the ABS or traction or both in my 182..it either stays there for the journey, vanishes mid journey or doesnt come up?
Mine has done this from day 1, never found a solution, Renault just re set computer and off you go! Ive found it happens on mine if you pump the brakes when stopping, usually i just switch off the ignition (if im stopped at a red light) and back on again to clear the fault. Just remember if u drive with the lights showing your ABS and traction control is disabled and wont work until u re set them via your ignition.
This is the notorious brake pedal switch fault IIRC. I had it with my shed, and many other people have had it too. I'm not sure if if it needs a new switch, or just adjusting. A dealer did mine in less than 20 minutes so it won't be a big expensive job.
