shocks help
  Clio 197
I need some help please:o
I got Apex springs 40mm I need to know which shocks will fit on my clio & the springs.
my clio is mk2 ph1 1.2 8v - 52mm
Blistein have some availiable I'm sure. Apex do a set. FK do a shock I'm sure but not that popular.
Or you could just go to 58mm hubs as there more common but there a reasonable choice for either.
Clio G-B said:
how hard to change the hubs and how much are they??:)
Dead easy just need to remove the 30mm hub nut the stearing rack ball joint and the two bolts for the ball joint.
Drop me a line if you want to pop over and do it at mine.
Cost well you could try your friendly brekaers say £40~60 for a set. Thing is whereaver you get a set from there bearing won't be as worn as your will be at 100k+ most doner cars you'll be using will have 1/3 that milage.
