Nope, don't do it! They look nice and give the change a much more mechanical feel but the damage they can inflict on the internals is not worth the risk (IMO).
I've not seen it but I assume it works on a similar principal to every other short shifter out there for these cars which will rush the change
I've made a 'base' conversion kit for the Renault gear linkage. This kit replaces the sloppy ball joint housing in the gear stick housing, the flexible ball insert (on the gear stick) and the small metal bush in the elbow joint at the gearbox. This base kit stop the movement/play of the gear linkage, gives very precise shift feel without the risk of damaging the gearbox. It's 'invisible' when it's fitted.
This kit maybe supplemented by brass bushes. These ones replace the red nylon bushes in the bottom of the gear stick.
Additionaly, short shift link may be used together with this kit. Faster gear change may damage the sinchro rings, it's fact. This is why I've made 2 versions of the short shift link. The shorter one is identical to the the well-known short shift links (made by other companies), it gives approx. 15% shorter shift throw (although other people say it can shorten the shift throw up to 30% in itself...) and probably will decrease the lifespan of the gearbox. The other type of mine is a longer short shift link, it gives approx. 10% shorter shift throw. I think it's a good balance between shorter throw and lifespan. It doesn't cause too much extra stress for the synchro rings but you can feel the difference in the shift throw, compared to the genuine shift throw.
How much is the 2nd kit Yanoo?
yes a big difference. i have uprated bushes on my linkage - awesome kit.so all in all does it make any diffrence ??
You still doing these kits?I've made a 'base' conversion kit for the Renault gear linkage. This kit replaces the sloppy ball joint housing in the gear stick housing, the flexible ball insert (on the gear stick) and the small metal bush in the elbow joint at the gearbox. This base kit stop the movement/play of the gear linkage, gives very precise shift feel without the risk of damaging the gearbox. It's 'invisible' when it's fitted.
If I'm not mistaken he's sadly passed away.Post revival
Oh! s**t!If I'm not mistaken he's sadly passed away.
