Simple yes or no suspension question
You'll have to check your bolt spacing Jez. You're looking for 58mm for all sport suspension (excluding 182cup/trophy which is 60mm). I'm not sure whether yours are 52 or 54mm. Would just mean changing hubs/driveshafts I'd imagine.
my bolt space on my non sport ph1 is 58mm? and ive got coilovers from a ph2 on mine and it fitted fine.
youll have to measure your bolt spacing and compare, measure centre of bolt to centre of bolt on the front
Bottom of the hole to bottom of the hole is easier ;)
Will the standard suspension off a mk2 ph2 fit a mk2 ph1 without any issues?
Simple answer = NO
nonsports will have either 52mm bolt spacing or 58mm bolt spacing.
NORMALLY 8v=52mm
and 16v=58mm,
but good old renault have a habit of mixing a matching when building clios!
