im in the same trouble at the minute, they do fit but cant guarantee that they will work ok, i got a new shaft and it had a rear one fitted, abs then started juddering at low speeds. the width of the rings are different and the sensor cant pick up a true signal from the ring. they can be got but are close on £50 incl delivery. renault say they cant supply them tho.
So the diameter of the sport ABS rings is the same front to back, but not the length of the teeth? am i getting this correct?
The length of the teeth off the rear is 7.50mm does anybody know if this is the same for the front??
