2003 Clio 172
So I had my belts changed last week and since then the car has a very slight misfire just below 2000 revs which dissappears when the engine is up to temperature. From reading through various threads on here the symptoms seemed to match the timing potentially being out slightly. Car has been back at garage since Tuesday and they have been unable to find anything wrong with it. I asked if they had physically checked the timing and they told me they didn't need to as car had been hooked up to diagnostic computer and the cam timing, dephaser etc were fine on there. I didn't think you could check the timing via diagnostics. Am I being fed a line? The garage is a reputable renault specialist so I'd like to think they know what they're doing but the fact they haven't felt the need to visually check the timing sounds a bit odd.
