Slow wipers
Car  Clio III Dynamique
Got a wee issue with the car I'm needing some help with. It's a 59 plate mk3 1.2.
basically, windscreen was a bit dirty so put the washers on, the wipers went to the top of the screen (vertical) and wouldn't go back to their rest position no matter what I did, turned car off then back on, still not moving, messed about with the stalk and they started working again, only now they are really slow, intermittent they take ages to move, normal constant speed is really slow and the fastest setting is now slower than what normal used to be, the wipers also now park about 2-3 inches further up the screen than they used to.
any ideas what's wrong?
May well be the motor. Could also be the linkage seizing up.
Very common with Audis to have the slow wiper issue. Normally solved by taking the mechanism apart and re-greasing everything
