Small oil leak (182)
Car  2015 ST2(MO)/CorsaLE
anyone had a oil leak from this nut...wont tighten up any more..
any suggestions folks ;)
The only fix is 7 hours or so you also change the cambelt to take that bit off.
Dn't overtigthen the holes its only ali.
ill stick with my dads suggestion a spot of super glue then...seems to be doing the job :o
thanks
I had the same thing on my 182, had to have the cambelt off etc. It was all under warranty so wasn't too bad. The car seemed to have a tiny bit of heavy idle though after, but there was nothing I could do / get changed to fully cure it.
I'd stick with the superglue option.
^^ thanks..but it turns the super glue yellow - i wonder what temp superglue goes up to :S
I did hear that some dealers quick fix was to take out 1 bolt at a time and put loctite under the flange head of the bolt.
