Snow Foam
omg i bet it works just as good as a lance connected to karcher. which i will be gutted by as just bought AB lance which cost 40 quid lol
for £9 mate it did the trick, just wonder if there is anyway of getting a thicker layer of suds on the car. what i used worked fine, but just wondering if there is a way to take it further?
Wow, that looks quite good for £9!!
I may invest in one of those. Can you use it with normal car shampoo (carplan stuff or turtle wax) or do you need to buy certain products?
No need for a bucket? Do the suds not dry before you wash the whole car?
no no, still bucket, but loosens a lot of the dirt, theoretically cutting down washing time.
Not as good as a pressure washer unfortunately but still okay for a tenner
Never use a pressure washer unless it's caked in mud.
Normally wet the car with the hose, leave for a min then get to washing with a mitt and 2 buckets, a panel at a time, and rinse before moving on to the next panel so not to let it dry.
Ok, will look into it with the products recommended then!!
i just filled the bottle up mixed 3:1 as said, then kept going round the car until the bottle was empty. let that sit for a minute or two, then wash as per normal routine. certainly loosened the dirt off the lower sills.
Not really keen on the supersprayer . Not enough foam for me and no pressure .
I meant a pressure washer foam lance sorry not just a pressure washer
superspray is more than adequate. just mix in some ssf with your chosen shampoo and the jobs a good un. more than enough suds to soften salt and general stuck on dirt.
