Snow foaming.
Typhoon
Gangsta
Hi guys, probably a silly question but where am I going wrong in snow foaming my car?
I'm aware as I'm only using Demon snow foam it won't be the best foamer but mine is literally like white water.
I have the k'archer K2 and that came with a snow foam attachment which doesn't have a thickness control knob on it but all I'm doing is putting that attachment on, filling it with the solution and then spraying.
I'd read about diluting the solution first, is this the case?
Typhoon
Gangsta
Cheers dude. Do you know any high street shops I could pick one up from today?
Sprayed it earlier and this was the result:
TheEvilGiraffe
South East - Essex
The thing you're using is just a shampoo spreader. It's not a foam lance.
Buy a proper lance if you want proper foam.
You won't find them in the shops.
Jonnio
  Punto HGT Abarth
Pretty sure you'd have to order one unless you live near a detailing place that happens to be open.
Doesn't look a bad effort from the pic.
  172 Cup & Mini C 1.6
The karcher attachment is not very good. Invest in some autobrite magifoam & a autobrite snow lance and use discount code ABforever 15
MRBILLYUK
  FF Jeden Osiem Dwa
If you don't want to shell out 40 quid for a foam lance , then do what i do . Get yourself a 25 litre home brew fermenting bucket ( approx 12 quid from a homebrew shop) , a length of hose into the bucket , fill up with warm water and snow foam / shampoo of your choice and you have lots and lots of " high pressure " foam using your normal pressure washer lance . I have a Vario lance for my Karcher , so i can have both high pressure and low pressure to rinse off .
Typhoon
Gangsta
Where in London are you, i4d offer an order online collect in store service
Hi Dave - I'm actually in Windsor now!
Good idea mate! I find the vario lance incredibly weak, even at maximum setting.
MRBILLYUK
  FF Jeden Osiem Dwa
Really ? Mine has plenty of power , good enough for cleaning moss etc off patios and is perfect for prewashing the car and high power foam . I've used this method for years and it's always shifted even the most stubborn caked on dirt .
That's not the best foam in the world, but it's a hell of a lot better than the foam you get from the standard attachment! Good work!
Didn't realise MAD sold them, I'm only down the road ... Just bought my snowfoam lance from shopnshine, as well as about another £200's worth of cleaning stuff (inc a das-6 pro). Is it sad that I can't wait for it all to arrive?
You're among friends here, pal.
Hoping to post some progress pics on Friday when the car gets the most intense cleaning its ever had ... I've always kept it beautifully clean with an enormous array of autogylm products, but I thought now was the time to take it to the next level :). Clay, iron x, poorboys wax, snowfoam, machine polishing : its getting the works!!!
MRBILLYUK
  FF Jeden Osiem Dwa
That's just with a weak dilution of shampoo and water , 25 litres and a couple of cap fulls of shampoo , compared to alot stronger mix you guys use with a snow foam lance .
In reality , is having an inch thick layer of foam on your car any better than the method i use ? At the end of the day it's only the bottom layer of the foam that is in direct contact with the paint that is doing any of the work , breaking down the dirt , grease etc ...... the top layer is more for effect imo . Plus the method i use , shampoo direct from a fermenting bin at high pressure is going to shift more of the dirt both physically as well as chemically , the snow foam lance only relies on the snow foam attacking the dirt albiet at low pressure .
I always rinse the car first with the pressure washer at high pressure to remove as much of the dirt as possible , then use the fermenting bin method , then rinse again and continue with the 2 bucket method and a wash mitt . This isn't a criticism by the way , just a bit of info for an alternative / cheaper method than paying circa £40.00 for a snow foam lance . All you need is about 6 foot of hose , a fermenting bin for a tenner , you can use a bucket but the bucket will empty very quickly .
Like you say . The standard Karcher attachments are nigh on useless .
The aim of thicker foam is less water so lighter foam, this ensuring it clings for longer. You're right that it's the bottom of the foam that acts, so the longer the cleaning agents cling, the better they clean. It's not just for looks.
And it's not the pressure that shifts it, although I think I've misunderstood your bit about high and low pressure spraying snow foam.
Tbqfh I don't snow foam any more at all. I see better results from presprays like RDS and AFCP!
MRBILLYUK
  FF Jeden Osiem Dwa
Like ya say , you obviously use alot more water using my method , so it does run off the car alot quicker , but you can see if taking the dirt with it as it drips off . Tbh , i've only ever used snow foam a few times . I have a 5 litre bottle minus a few capfulls somewhere knocking about in my garage , i usually just use shampoo as i've found that worked well enough . My way of thinking is , lots of high pressure foam will help remove the majority of the dirt not just chemically , but physically too .
  Fiesta ST3
I think snow foaming is over hyped. It looks good and that's about it
I've used all major brands over last 2 years and if doesn't do much IMO
one inch product and rest water. In an autobrite lance. Foams like crazy but not very effective
Yeah it clicked just after sending that post ha.
When I do snow foam, I use Megs Hyper Wash. Which is a shampoo. So agreed!
There are the good, the bad and the down right useless. But it does do something, just not as effectively as a pre spray IMO.
Coby.
But it looks fun!!!
I'll be getting a Snowfoam lance off the Missus next weekend.... Need? No. Want? Yes :)
Waitey
  Alpina D3, AC Cobra
The MAD one doesn't work very well.
Even running neat Snow foam in it.
Mr R.
  A special one.
But Halfords is the only place I can go to today.
What about buying the demon shine stuff for now?
Then next week you can organise yourself a bit better and but the correct lance and a bottle of foam??
You are so last minute matey. Flol
Herr Flick
aka Herman Ze German
Not going to luton today then? Lol
ill have a butchers when the least c***s open at 9. Saw the demon shine foam stuff so will see if they have that for now.
