Socket A vs Socket 939 CPU cooling
Currently got a Socket A AthlonXP along with water cooling.
If I was to upgrade to an Athlon64 (obvy with new motherboard) then are the clips for the CPU cooler still the same or will I need a new CPU cooler block?
Thnx
Very different. Socket 939 coolers have a different clip system which hooks onto the plastic socket surrond.
The cooler AMD supply these days is really good. I installed one on a new X2 4800 yesterday and the fan didn't even need to start spinning for the first 5 minutes of operation. They are nice heatpipe ones.
Obviously you'll want more if you are overclocking.
it has a 12cm fan on the other side of it. its the first btx pc i have been inside
I have a watercooled 939, I had to remove the plastic mounting bracket from the board and it slipped through the holes beneath
I thought the Socket A boards had very similar holes! Check out the Waterchill kits, it will say what CPU they support, I am sure mine supported Socket A as well!
Its that big because thats the newer BTX system meant for better more silent cooling.
I have one of the zalman fatality heatsinks in mine pretty quite and rather big good enough for overclocking my cpu anyways. Water might get me a little higher but not much.
Thats the point puts airflow in a straighter line having the cpu get the most cool air etc.
Most computers will go btx over the next few years just not a mad rush for it right now. Really isnt that big a deal.
